Forums >> Revit Building >> Technical Support >> 3D line based hosted family template or solution
Sat, May 2, 2009 at 11:53:45 AM | 3D line based hosted family template or solution
critter
I would like to host a series of 3D Line-Based Familes in walls, ceilings, floors, and roofs. I am looking for the capability of a 3D line based family being able to be re-sized in length, while being able to have it be hosted in other objects.
Any thoughts?
Sat, May 2, 2009 at 12:13:32 PM | 3D line based hosted family template or solution
A line hosted family is just that...  If you want a face based family, use that instead.  Maybe if you were more explicit on what you are wanting to do.
Sat, May 2, 2009 at 1:02:16 PM | 3D line based hosted family template or solution
critter
I am preparing to model a series of expansion joint covers.I would like to include a void form in the family to subtract from  the host I insert the joint cover in to.
Sat, May 2, 2009 at 1:46:17 PM | 3D line based hosted family template or solution
critter
Changing the "length" to an instance parameter allowed me to adjust the extrusion as I would a line based family. See attached.
How would you modify a family from face-based or hosted to one that is not?
Mon, Sep 26, 2011 at 8:39:50 AM
Is it possible to make a line-based family wall based?
Wed, Jan 5, 2011 at 1:00:21 PM
Line Based Template File 9.1
Thu, Jan 10, 2008 at 3:47:33 PM
Family Typical Model based on line
Mon, Dec 22, 2008 at 7:55:47 AM
Creating an expansion joint family
Sat, May 2, 2009 at 10:57:03 AM
Page generation time: 2.1633
