Forums >> Revit Building >> Technical Support >> Splitting a wall with a Reveal
Fri, May 1, 2009 at 3:54:50 PM | Splitting a wall with a Reveal
sloman
Hi,
 I'm using Revit Archtitecture 2009 and I've run into a snag that I haven't found a solution to.  I have a horizontal reveal running along a few of my walls that is about 2/3rds of the wall up the wall.  I want to paint the wall above the reveal one color, and below the reveal another.  The problem is that I cannot split the wall along the reveal because when you enter the split face editor, it shows that the wall is already split where the reveal is drawn, but if you try to paint that upper portion of the wall, it still paints the entire wall.  I tried splitting the face of the wall first and painting it the two seperate colors, but then when I apply the reveal, it wants to delete my splitting element.  Any suggestions?  Am I missing something or is this a bug?  If so, does anyone have a snazzy work-around?  I've attached a screen shot of my wall in the split face editor.  Also, I really don't want to create another wall type and make the split in the assembly itself because only portions of my walls actually have this reveal.  Any help would be greatly appreciated!
Sat, May 2, 2009 at 2:35:29 AM | Splitting a wall with a Reveal
tim123
4 Stars: 19 Votes
Split the face below the reveal.
Sat, May 2, 2009 at 8:40:14 AM | Splitting a wall with a Reveal
4 Stars: 205 Votes
Sloman, see the video: http://www.megaupload.com/?d=A5IC5L05
Mon, May 4, 2009 at 12:12:34 PM | Splitting a wall with a Reveal
sloman
Thanks for the advice guys, but that only seems to work if I split the entire wall so that I have two seperate walls stacked on top of one another.  This may be the route I am forced to take, but I would really like the wall to remain one wall and only split the face of the wall on one side.  Not possible?
Mon, May 4, 2009 at 1:17:44 PM | Splitting a wall with a Reveal
4 Stars: 205 Votes
SO??? use the Stacked wall....
Thu, Feb 18, 2010 at 4:47:02 PM | Splitting a wall with a Reveal
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
It's a bug in the software. Try this.
cad.web.print
Fri, Feb 19, 2010 at 11:03:49 AM | Splitting a wall with a Reveal
sloman
Bm3875.  Thank you so much for this link!  That was the exact problem I was having!  Much appreciated!
Fri, Feb 19, 2010 at 11:25:44 AM | Splitting a wall with a Reveal
TomDorner
4.5 Stars: 25 Votes
I would use a "compound wall".  In the wall editor you can assign multiple materials to the same layer thickness within a wall.  (Hopefully this is where you added your reveal as well).  In the wall editor, make sure you activate the preview and set to section.  Then explore the use of "split region" and "assign layers".
Tom
www.reviteer.com   http://twitter.com/Reviteer
how to add a self made reveal to a wall while edit wall types?
Sat, Feb 12, 2011 at 10:53:31 PM
Dimensioning to the Centerline of a Wall Reveal??
Wed, Oct 19, 2011 at 10:28:03 AM
Wall Reveal-Please HELP!!!!!
Fri, May 26, 2006 at 9:12:01 AM
Wall Reveal under Window Opening
Thu, Jul 17, 2008 at 6:45:24 PM
REVEAL QUESTIION
Wed, Mar 9, 2005 at 5:07:49 PM
Page generation time: 1.4530
