Forums >> Revit Building >> Technical Support >> Mirror about manual axis in 2010??
Fri, May 1, 2009 at 11:49:43 AM | Mirror about manual axis in 2010??
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
I am using 2010 and I noticed on the mirror command you can no longer select to draw an axis??  Am I missing it?  I can only select existing lines to mirror about.
Any help would be greatly appreciated.  Thanks,
Lorne
Denver, CO
Revit Architecture
Fri, May 1, 2009 at 12:12:20 PM | Mirror about manual axis in 2010??
Click on the objects to be mirrored ... then from the modify menu - don't pick the mirror - pick the down arrow next to the mirror - that is where your mirror options are .... kind of burried.
Fri, May 1, 2009 at 12:18:21 PM | Mirror about manual axis in 2010??
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Aww, thanks.  I'm still getting used to the ribbons since microsoft added them to office.  Now that it's in Revit I'm forced to learn this.  I don't like it.  All my shortcuts are messed up too!
Thanks for the help.
Lorne
Denver, CO
Revit Architecture
Fri, May 1, 2009 at 12:58:25 PM | Mirror about manual axis in 2010??
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
the mirror command was the first one to be added to my quick access toolbar! I am on like my 8th different setup of the quick access toolbar. two other must haves are worksets and design options
Fri, May 1, 2009 at 1:26:16 PM | Mirror about manual axis in 2010??
alabaster,
Rather than adding my worksets to the quick action bar, I ripped it off the ribbon and pasted it to the right of the ribbon so that I can always see the current workset.
Fri, May 1, 2009 at 1:44:29 PM | Mirror about manual axis in 2010??
alabaster2513
3.5 Stars: 25 Votes
thats a really good idea! did you just have to move it down slightly so it doesnt redock with the ribbon?
We should start on going thread about Ribbon Customization to aloow people to see what others are doing to enhance their interface!
Fri, May 1, 2009 at 3:23:46 PM | Mirror about manual axis in 2010??
Yes, it is only patially above the work area ... any higher and it jumps back on the ribbon.
objects move in Y-axis but not X-axis
Wed, Nov 2, 2005 at 11:04:31 PM
Revit 2010-Have we lost one of the mirror options?
Fri, Apr 24, 2009 at 11:35:08 AM
user manual
Wed, Aug 30, 2006 at 1:15:06 AM
using the mirror comand [ 1 2 ]
Thu, Oct 15, 2009 at 9:13:36 AM
20
Revit 2010 books
Thu, Jan 14, 2010 at 12:20:31 PM
14
Page generation time: 0.3599
