25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Custom Room Parameter tag
24 Posts No Rating |
Hi I am setting up a room tag and I would like to add my own parameters, but they do not seem to work probably in my project neither can I pick them up in the room schedule? Am I doing something wrong or is this not possible with room tags? thanks.
It needs to be a shared parameter, not a family parameter for this to work. The family parameter is the default when you add parameters.
tim123, thanks alot it works!
check out http://www.aecbytes.com/tipsandtricks/2008/issue33-revitarch.html if you really want to learn Reivt Family Creation www.will2play.com
www.will2play.com |
URL parameter in a room tag |
Thu, Feb 18, 2010 at 3:55:55 AM
Using Room Tag Family Parameters in a Celing Tag Family |
Mon, Sep 22, 2008 at 7:52:40 AM
Visibility Parameter in Room Tag |
Fri, Jun 4, 2010 at 6:01:09 PM
Custom room Stamp/Tag in Revit |
Sun, Oct 17, 2010 at 9:42:00 PM
room temperature parameter in room tag??? |
Wed, Oct 27, 2010 at 3:38:08 PM
