Forums >> Revit Building >> Technical Support >> Render Apperance in 2D
Wed, Apr 29, 2009 at 9:38:48 PM | Render Apperance in 2D
tam3105
Hi,
Can anyone give advise on Render apperance in 2d. I have 2 floor levels and set the render appearance for materials, but the render apperance on the Ground Floor Plan is alot darker than the First Floor Level.   If a show the floor plan on the Site plan it is okay, but on the Ground floor layer it is showing darker.  I have tried everything so i think and am getting very frustarted.  Can anyone help please.
Tammy
Thu, Apr 30, 2009 at 11:46:41 AM | Render Apperance in 2D
tim123
4 Stars: 19 Votes
Are you talking about the render appearance or the shading appearance?  If the latter, just use a view template from the view that displays correctly and apply it to the other views.
Thu, Apr 30, 2009 at 1:33:17 PM | Render Apperance in 2D
4 Stars: 205 Votes
"Can anyone give advise on Render apperance in 2d." - This, i don't understand either...
Thu, Apr 30, 2009 at 4:02:58 PM | Render Apperance in 2D
tam3105
Tim you are a god send.  Thanks heaps what was doing my head in took 10 seconds to fix.
Mullions won't render
Wed, Jun 24, 2009 at 4:09:30 PM
shader and render colour problems
Tue, Sep 15, 2009 at 5:58:17 PM
3d model shows wireframe while in shaded mode
Mon, Oct 3, 2011 at 4:27:32 PM
daylight portals 0
Mon, Jul 12, 2010 at 2:01:04 AM
3d display question
Wed, Apr 15, 2009 at 11:14:14 AM
Page generation time: 1.6519
