Forums >> Revit Building >> Technical Support >> Copy Wall Section
Wed, Apr 29, 2009 at 9:50:14 AM | Copy Wall Section
davbrink
4 Stars: 1 Votes
Quick Question.  I want to move a wall section tag from one view to another. I tried coping the section mark and pasting in the other view and it creates another section view. I have cleaned up the first and do not want to have to repeat all of my work.
 On a similar note how do you havetwo or more idenical detail tagged in two different locations on the plan and have them reference the same detail?
Wed, Apr 29, 2009 at 9:54:06 AM | Copy Wall Section
View tags create the views ... they are not independent.   The tag will assume the values it should have when you place it on a sheet.  If you want a different view on the sheet - then remove the one and place the one you want.  If you want a different order, then renumber your views on the sheet.
If you have data in one view and you want that in the other ... you may be able to copy/paste it view to view.
Edited on: Wed, Apr 29, 2009 at 9:55:34 AM
Wed, Apr 29, 2009 at 10:20:17 AM | Copy Wall Section
davbrink
4 Stars: 1 Votes
That is what I was afraid of. But I did find a work around. I hid the section tag in the one that I did not want it in and created a reference section tag in the other plan view and overwrote the "SIM" field.
Cannot figure out how to copy a wall section up to next story?
Sun, Oct 13, 2013 at 7:57:01 AM
Copy/paste section to new project
Thu, Sep 10, 2015 at 10:21:13 AM
i connot copy the wall on my COPY-MONITOR tools
Mon, Apr 11, 2011 at 11:51:16 AM
Managing multiple copies of a building section in the same project
Fri, Oct 25, 2013 at 1:04:53 PM
Using 2d group for Wall section, section details called out from wall section?
Fri, Oct 9, 2015 at 10:50:56 AM
Page generation time: 1.5206
