Forums >> Revit Building >> Technical Support >> Family Parameters question
Tue, Jul 12, 2005 at 2:45:22 PM | Family Parameters question
dorri
I am working on a window in the family editor, and I'm having trouble with some of the dimensions in the family types dialog box. There are dimensions for "Width," "Height," "Rough Width," and "Rough Height" that cannot be modified or removed, and I cannot tell if they are instance or type parameters. The file I am working on was created by someone else so I don't know if these dimensions/parameters are there by default or were created by the previous user. Is there any way I can manipulate these dimensions to my liking? Thanks
Tue, Jul 12, 2005 at 4:14:25 PM | RE: Family Parameters question
JoeDrevitO
Hey, the parameters you are talking about are family type parameters. Depending on which type of family you are working on (picked in settings, family category and parameters) you will be forced to include some parameters in your project. The ones you mentioned are type parameters. If you dont want to use them and dont want them getting in the way you have to change your family category to something like generic models (wont be listed under windows in the project anymore if you do.) Otherwise you are stuck with these parameters just how they are, you can change the value but not much else. Cheers!
How do you edit mullion profile parameters
Thu, Oct 27, 2011 at 10:42:17 AM
Blue ? ( question mark) shared parameters [ 1 2 ]
Mon, Jan 17, 2011 at 1:17:42 AM
21
Associated Parameters in Array Family
Mon, Feb 27, 2017 at 8:44:36 AM
How to link shared family parameters into an assembly titleblock?
Mon, Apr 20, 2015 at 8:14:15 AM
Yet another Shared Parameter Question
Tue, Sep 22, 2009 at 2:39:07 PM
Page generation time: 0.7573
