36 Users Online (34 Members):
Forums >> Revit Building >> Technical Support >> Wall cleanup issues
I'm having some real issues with wall cleanups in my residential remodel projects. (Revit09) Haven't loaded up 2010 yet as I am mid project but maybe that will change things. My walls aren't cleaning up and I spend a lot of time fixing in one view, then I go to the next level and have to do it all over again. I know one issue is that non bearing walls don't want to clean up with bearing walls which makes zero sense. My reseller tech support tells me that I should consider drawing my existing and new construction phases as totally different projects. That would be pathetic!!! If this software is so underdeveloped that it can't perform what it is intended to do,... well I'm not buying that. Hopefully someone can take a look at the screenshot below and clue me in on what I need to do to avoid this BS. Blue walls are bearing, green are non bearing, notice all the green in rear left not cleaning up and the gap in the walls at the far left. Got em all cleaned up in floor plan. Then, in this roof plan they are all jacked up.Thank You.
20 Posts No Rating |
Well, a couple of things, first, it might be easier if you just posted .jpg's instead of word docs for us to look at and answer problems.Second, I've never had a problem joining and fixing joins for bearing and non-bearing walls, but generally speaking the 'bearing' wall classification always seemed pointless unless I'm working with a structural engineer using Revit Structural, are you a struct. engineer? Maybe just make all your bearing walls non bearing, and just create a different wall type with different graphic settings.Finally what's wrong with those walls at the back? Not sure about that gap. For better screen printing check out http://www.jingproject.com/Free very good screenprinting tool
Sorry I couldn't be of more help...
Edited on: Wed, Apr 29, 2009 at 12:56:00 PM
Right click a problematic wall and see the element prop, graphics, Wall Join Display-see if it shows "Clean all wall joins".
Motto: "No Post left behind" |
Sorry, not the elem prop but the view prop.
Thanks all. I'll check on these things and see where it gets me.
Custom Wall Cleanup tool |
Mon, Jan 18, 2016 at 2:12:14 PM
Wall Floor Intersection Cleanup |
Thu, May 4, 2006 at 12:06:45 PM
230 brick wall wont cleanup to 250 brick veneer wall (images attached) RA2008 |
Wed, Sep 3, 2008 at 12:33:09 AM
wall cleanup radius |
Thu, Aug 9, 2007 at 4:56:14 PM
WALL JOIN CLEANUP TOOL |
Tue, Aug 16, 2011 at 2:41:10 AM
