Forums >> Revit Building >> Technical Support >> Hide top of walls
Tue, Apr 28, 2009 at 2:52:42 PM | Hide top of walls
fastjohnnyz
  I have a 2 story house. I go to a 3d view and then use the crop box so that I can see all the walls and layout of the 2nd floor. I have shading with edges on so that the layout is more clearly visible. But the problem I am having is that I can see the top of the walls from the first level on the 2nd floor. I currently have the 1st floor walls top constraint to go to the 2nd level. I went to the element properties dialog box and couldn't find anything to turn them off. Plus I don't even want them to go that high. I have 12" deep joists. So I would like for the stud walls to stop at the bottom of the joists. Please advise.
Tue, Apr 28, 2009 at 3:13:43 PM | Hide top of walls
4 Stars: 205 Votes
An image of that clarify the problem....
Tue, Apr 28, 2009 at 3:31:48 PM | Hide top of walls
travistlo
5 Stars: 2 Votes
You need to tell your walls to attach to the bottom of the floor, not to the second floor level.
 Edit the floor, and it will ask you if you want to attached the walls below to the floor. And it will move the tops of all the walls down to the bottom of the floor.
You can also "cheat" and copy your floor ontop of itself, make it 1/8" thick, and it will hide the walls below.
Right now you are seeing co-planer surfaces (The top of the wall and the top of the floor are EXACTLY in the same position)
Chatting it up on gmail - travistlo.j@gmail.com
Tue, Apr 28, 2009 at 3:38:49 PM | Hide top of walls
fastjohnnyz
Thank you very much. I was actually cheating another way by going to my sections and doing an align command. Much more time consuming. You way is soooo much easier. Thanks again
Structural walls in Architectural Model
Fri, Aug 6, 2010 at 9:51:37 AM
HOw Do i HidE ThOse Lines ?
Mon, Oct 30, 2006 at 9:03:35 PM
Hide Walls Below - New to Revit
Wed, Sep 3, 2014 at 8:13:22 AM
Transparent countertop?!?
Tue, Oct 14, 2008 at 2:18:56 PM
Top Finish on Walls
Wed, Nov 29, 2017 at 1:55:05 PM
Page generation time: 2.8031
