Forums >> Revit Building >> Technical Support >> topography in elevation shows up "blank" space. any work around?
Tue, Apr 28, 2009 at 11:22:18 AM | topography in elevation shows up "blank" space. any work around?
coonrodg
It looks like the topography "behind" my elevation shows up as a blank. What controls the level that my elevation symbol shows up in plan view. This particular elevation only shows up on the basement floor plan and not on the site, first floor, etc.
 Thanks,
Garrett
Tue, Apr 28, 2009 at 1:09:53 PM | topography in elevation shows up "blank" space. any work around?
mhans
3 Stars: 10 Votes
Try putting a pad.
Motto: "No Post left behind"
Tue, Apr 28, 2009 at 1:12:37 PM | topography in elevation shows up "blank" space. any work around?
4 Stars: 205 Votes
Put some 3D views images of that zone to check....
Tue, Apr 28, 2009 at 2:03:34 PM | topography in elevation shows up "blank" space. any work around?
coonrodg
Here is a 3D view of the house.
Tue, Apr 28, 2009 at 2:14:42 PM | topography in elevation shows up "blank" space. any work around?
4 Stars: 205 Votes
In that view, move your elevation symbol near to the house....
i think your elevation is cutting that portion of site (topo)....
Tue, Apr 28, 2009 at 2:23:46 PM | topography in elevation shows up "blank" space. any work around?
mhans
3 Stars: 10 Votes
Adjust your section cut closer to the building (or jag it). I think you are cutting parts of your contour when doing the cut.
Tue, Apr 28, 2009 at 2:55:27 PM | topography in elevation shows up "blank" space. any work around?
coonrodg
I tried to move the elevation. Thats why all I can figure is the the elevation looks "backwords" a little ways for some reason.
Tue, Apr 28, 2009 at 2:59:34 PM | topography in elevation shows up "blank" space. any work around?
coonrodg
Maybe this screen shot is a little better.
Tue, Apr 28, 2009 at 3:21:52 PM | topography in elevation shows up "blank" space. any work around?
4 Stars: 205 Votes
Hummm, can you please put here the model so i can take a look??? ATTENCION, you can upload only 2MB...
Tue, Apr 28, 2009 at 3:43:40 PM | topography in elevation shows up "blank" space. any work around?
mhans
3 Stars: 10 Votes
Going back to your 3D screen shot, there are green and black contours. Does that represent your existing and proposed grades? See to it that only one is active in your view. Check your visibility setting.
Tue, Apr 28, 2009 at 4:19:17 PM | topography in elevation shows up "blank" space. any work around?
#11
4 Stars: 205 Votes
I think that brown surface it's a "Subregion", i don't know....
Tue, Apr 28, 2009 at 6:30:20 PM | topography in elevation shows up "blank" space. any work around?
#12
coonrodg
I do have a subregion that is the driveway/asphalt. My file size is 4mb. Is there a way to only send a "model"?
Wed, Apr 29, 2009 at 3:20:42 AM | topography in elevation shows up "blank" space. any work around?
#13
4 Stars: 205 Votes
Send me by email (check my profile)....
Blank spaces in topography
Thu, Jun 2, 2011 at 3:00:14 PM
Specification column "Elevation at Bottom"
Wed, Jan 28, 2009 at 7:43:12 AM
14
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
room tag blank field
Tue, Sep 25, 2007 at 8:33:16 PM
Spot Elevation/ Level with both "project base point" and "survey point" 2017
Mon, Nov 27, 2017 at 5:33:42 PM
Page generation time: 1.9959
