Forums >> Revit Building >> Technical Support >> copying system families
Tue, Apr 28, 2009 at 10:06:29 AM | copying system families
line
Does anyone know how to copy a system family from project to project and keep the setting from the families that is copied ?We have had great difficulties using the legend setup as it can’t dimension or use the category tags we have setup in the project. Which mean all the cleverness of our components/ naming etc is not useful. To get around this we have decided to make a separate file with all the legends. (door, wall, beam etc.) However when I update some information in the legend I can’t simply copy it across to the other project and overwrite the setting in the other project Cryingonly the component families can be reloaded into both project). Any good suggestion how to keep intelligent legends?
thanks
Tue, May 12, 2009 at 12:24:23 PM | copying system families
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
transfer project standards
http://familyjewels.typepad.com/
Tue, May 12, 2009 at 12:36:29 PM | copying system families
line
Thanks! Must have missed that one as it was so obvious.
Wed, Jun 10, 2009 at 10:52:08 AM | copying system families
Eddieboarder91
4 Stars: 8 Votes
no worries, easy fix
copying system panels between projects - how should it be done?
Wed, May 29, 2013 at 8:41:33 PM
13
Editing System Families
Sat, Dec 5, 2009 at 3:53:10 PM
Help: Copying families from one drawing to another
Mon, Apr 21, 2008 at 3:27:22 PM
Worksets: Copying from one drawing to another?
Tue, Jan 5, 2010 at 4:53:39 PM
Reload System Families
Sun, Oct 2, 2005 at 5:17:26 PM
Page generation time: 4.9350
