Forums >> Revit Structure >> Tips & Tricks >> 2010 Modify Tool tip (this is good!)
Tue, Apr 28, 2009 at 9:25:17 AM | 2010 Modify Tool tip (this is good!)
jarosa
jarosa Avatar
4 Stars: 5 Votes
Here is a great tip. IMHO.
Select the Modify Panel.
The Modify tool is a nice size icon on its own panel. Rip that panel right off the Ribbon and place it on the top left corner of your drawing area (or wherever you like. I like it there because that is the general area where i spend most of my mouse time picking icons.).
This should help productivity if you use modify to end a command. Instead of trying to hit the tiny modify icon on the QAT or Right Click Cancel (2 clicks)...presto.
John
Tue, Apr 28, 2009 at 12:24:08 PM | 2010 Modify Tool tip (this is good!)
mongopac
Nice....I like it....
Thu, Apr 30, 2009 at 5:15:55 AM | 2010 Modify Tool tip (this is good!)
RolyNZ
RolyNZ Avatar
4 Stars: 3 Votes
Thanks bud, you learn something new every day!
www.Crawshaw Architecture.co.nz
Sun, Jun 21, 2009 at 11:33:10 PM | 2010 Modify Tool tip (this is good!)
AidanWeisz19
Thank you, john. This really helped me
General Contractors in Washington DC
Wed, Sep 9, 2009 at 7:50:21 PM | 2010 Modify Tool tip (this is good!)
snofreek
Uhhh....  ESC button on the keyboard not easy enough for you?
save to central
Wed, Sep 9, 2009 at 10:13:13 PM | 2010 Modify Tool tip (this is good!)
nafenn
This sounds amazing for lefties.
If however you are right handed, here's a nifty trick:
Step 1 - Hold mouse with right, do not let go!!!!
Step 2 - Place left hand in very close proximity to ESC button
Step 3 - Enter shortcuts / measurements with left hand
Step 4 - repeat Step 2
Peace.
Wed, Sep 9, 2009 at 10:23:03 PM | 2010 Modify Tool tip (this is good!)
RolyNZ
RolyNZ Avatar
4 Stars: 3 Votes
Classic!
Yeah esc key works on my keyboard too... it's pretty shiny
What is helpfull is by dragging out the edit tools, they become staic, there all the time.
Hopefully the Revit boffins will also manage to get the icons to stay relatively static in the next update.
Fri, Oct 2, 2009 at 7:56:44 AM | 2010 Modify Tool tip (this is good!)
leighton
It's really very helpful. Thanks for the tip!
Regards,Leightonprêts travaux
Sat, Oct 3, 2009 at 8:45:41 AM | 2010 Modify Tool tip (this is good!)
jarosa
jarosa Avatar
4 Stars: 5 Votes
As I said in the original post, "This should help productivity if you use modify to end a command." For those users that use the escape key, this tip isn't helpful. Ending with the modify tool is how I (and I presume many users) learned the program. I've been experimenting with the escape key since.
Happy Bimming to all.
Sat, Oct 3, 2009 at 3:53:08 PM | 2010 Modify Tool tip (this is good!)
RolyNZ
RolyNZ Avatar
4 Stars: 3 Votes
Hey I use the escape key, but I found your tip usefull in other ways, I didn't realise you could reposition the toolbars like that. They are a godsend to be able to have selected tools available all the time, + they don't jump around. My wish is that I could lock into position or customise the various toolbars, if they weren't available, perhaps grey them out. I know this uses up more screen, but I often find myself double, triple clicking to use a command too often in Revit.
tool tip text on sheet
Mon, Apr 18, 2016 at 10:38:52 AM
Tag dimensions to reference plane in 2010
Wed, Jan 6, 2010 at 1:41:42 PM
Revit 2013 Help.... Pick Lines tool box.
Mon, Jun 24, 2013 at 9:49:23 AM
Rollover Tool Tip box does not disappear
Wed, Apr 9, 2014 at 12:11:58 PM
Linework tool issue
Mon, Sep 26, 2011 at 3:20:44 PM
Page generation time: 0.4906
