Forums >> Revit Building >> Technical Support >> No Revit Shell
Tue, Jul 12, 2005 at 12:47:11 PM | No Revit Shell
aefordham
I am a novice in Revit and I will be starting a new project where the shell and core are being designed by another firm, that does not use Revit. I need to know what the best approach is in this case. I don't want to burn up my time building the shell which is in a Design development stage. But I do want to be able to realize the space in 3D.
Tue, Jul 12, 2005 at 4:38:22 PM | RE: No Revit Shell
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What program has the shell been created in? If you can get into some sort of 3D dwg file you could use that however if its all 2D and you want in 3D there is no other option other to model it? Unfortunately revit doesn't have an automatically build the rest of the building button... jk
Tue, Jul 12, 2005 at 4:54:16 PM | RE: No Revit Shell
aefordham
Thanks for the reply. The Architects are using arch desktop. As a novice would it be better to avoid any problems in the exterior and only create the interior walls in revit? Any advice is wecome.
Tue, Jul 12, 2005 at 5:45:55 PM | RE: No Revit Shell
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Well i'd suggest if they are using ADT that you link a DWG model of the shell and core that will allow you realise the space. Then you can just unload the link when it not needed.
Remove Working Views from Revit Projects with Python Shell Script
Mon, Mar 25, 2013 at 12:43:53 PM
Multiple Tenant Finishes - One Shell
Fri, Oct 3, 2008 at 1:47:22 PM
How to Delete all Empty Tags with Revit Python Shell
Mon, Mar 18, 2013 at 2:37:48 PM
Timber Shell Structure
Fri, Nov 30, 2012 at 3:39:18 AM
Seperate Core and Shell / TI Packages in CD
Wed, Dec 7, 2011 at 12:03:52 PM
Page generation time: 2.0744
