Forums >> Revit Structure >> Technical Support >> Concrete Slab Edge Angles
Tue, Apr 28, 2009 at 8:37:33 AM | Concrete Slab Edge Angles
TeamNga
1 Stars: 1 Votes
Hello everybody.
Does anybody know how I could add pour stop angles to my concrete slabs? I would like for my pour stop angle to be part of the slab, to be able to see it, tag it, and dimension how far off it is from the grid line when cutting a section. I was able to create steel deck and add it to my slab but not my angles. I created a slab edge profile but I get the "One element is completely inside another" warning. My angle is there but I can't see it or join it to the slab. Does anybody know a solution to my problem?
Thank you.
Tue, Apr 28, 2009 at 8:46:11 AM | Concrete Slab Edge Angles
travistlo
5 Stars: 2 Votes
Create your angle like you did. You might still get the error that one object is completly inside of another. Once created move your angle outside of the slab. You will get a warning that asks you to unjoin geometry. Then move your angle back to position. This will give you an overlap of hatching, but atleast you can see your angle.
Chatting it up on gmail - travistlo.j@gmail.com
Wed, Apr 29, 2009 at 3:51:30 PM | Concrete Slab Edge Angles
TeamNga
1 Stars: 1 Votes
Thanks but I am not looking to unjoin my angle from the slab. That would be last resort for me. I would like to have my angle be part of the slab just like the steel deck does. Is it possible to do that? If so, how?
Thanks.
Mon, May 4, 2009 at 10:35:00 PM | Concrete Slab Edge Angles
emgeeo
3.5 Stars: 7 Votes
Use a sweep.  You can do an in-place sketch, or you can create profiles based on what you need.  But, a sweep will work perfectly- just about.  Do you know how to do this?
Fri, May 8, 2009 at 9:07:25 AM | Concrete Slab Edge Angles
TeamNga
1 Stars: 1 Votes
When you say a profile based on what I need, do you mean creating a new profile using the Profile-Hosted template? I've never used that but I will give it a try.
Thanks.
Mon, Dec 5, 2011 at 8:32:04 AM | Concrete Slab Edge Angles
seniorcad143
1 Stars: 1 Votes
emgeeo - how do you do this in-place sweep for the slab edge?
Yeesh - Where is My Cad
Mon, Dec 5, 2011 at 9:17:49 AM | Concrete Slab Edge Angles
Just follow the method described in the HELP:> Creating a Sweep
Mon, Dec 5, 2011 at 9:26:31 AM | Concrete Slab Edge Angles
seniorcad143
1 Stars: 1 Votes
wwhub - is this the easiest and best way in putting in edge angles?
I just posted another question similar to this one.
Mon, Dec 5, 2011 at 9:29:23 AM | Concrete Slab Edge Angles
Maybe not.... If the slab is flat, I would use a face based family.  That would be much easier.  Create it so that it is adjustable in length.
Mon, Dec 5, 2011 at 10:22:30 AM | Concrete Slab Edge Angles
seniorcad143
1 Stars: 1 Votes
I will have to look up face based family and how to do it for my second floor, it is flat. -  so on my sloping roof I will need to create a sweep, even though revit had a angle in their library?
I am new to revit and I am still trying to figure out what to model, how to model it or what not to model and just place in section and then how to do that.
Mon, Dec 5, 2011 at 10:35:13 AM | Concrete Slab Edge Angles
Actually - the faced based should work for the slope too.
Mon, Dec 5, 2011 at 10:49:32 AM | Concrete Slab Edge Angles
seniorcad143
1 Stars: 1 Votes
ok - let me try this and I will let you know how it goes.
Wed, Dec 7, 2011 at 10:29:22 AM | Concrete Slab Edge Angles
#13
seniorcad143
1 Stars: 1 Votes
ok - so I tried this face base family - actually it is the slab edge modified.
1.  How can I have two cut patterns in one detail?  One for the concrete and one for the bent plate.
2.  I do not know how to pick it once I load it into my project - it is not showing up under the slab edge type in the properties box.  (image 2)
A image of the family is attached.  (image 1)
Wed, Dec 7, 2011 at 12:35:24 PM | Concrete Slab Edge Angles
#14
seniorcad143
1 Stars: 1 Votes
Please look at the above questions and then look at this one.
I tried the in place component (for my edge angle) with a thickened slab egde already placed.  (image below)
Questions:  I would like to change the OTB edge slab profile (I don't want the 45 degree slant) but I load it but it doesn't want to show up in the type editor.
I don't want the deck to show up going thru the thickend part.  Is there any way to sop it short?
Slab Edge with multiple layers
Tue, Feb 8, 2011 at 7:54:37 AM
"Could not create Slab Edge"
Tue, Feb 17, 2009 at 1:40:42 PM
RC upstand on the edge of an RC slab
Thu, Jul 14, 2011 at 11:04:56 AM
Revit 2010 Slab Edge Trouble
Mon, Feb 15, 2010 at 8:54:39 AM
slab thickening below hardcore
Wed, Jan 12, 2011 at 5:26:21 AM
Page generation time: 0.6549
