Forums >> Revit Building >> Technical Support >> copy view crops and view breaks between views?
Mon, Apr 27, 2009 at 9:10:53 PM | copy view crops and view breaks between views?
bradidea
Hello,
 I'm wondering if it is possbile to copy the view crop and horizontal view breaks from one view to another. Is there a way to do this in revit, or a relatively painless way to align the crops of several views. So far, I've just been eyeballing it, but the results are not really satisfactory.
In my case, I have a series of wall sections of various conditions in my building. For a typical wall section I have two horizontal view breaks because I only want to show the condition at the floor, the ceiling, and the slab above. There are various different cove, soffit, and ceiling/wall connections in these various sections. I want to put them all on a sheet, and have the detail crop regions, view breaks, break lines (...etc) align on the sheet.
Does that explanation make sense? Well, if the above isn't confusing enough, take a look at the horrible ascii illustration below. Any thoughts?
Thanks in advance!
-bradidea
   -v-    -v-    -v-
Tue, Apr 28, 2009 at 7:07:01 AM | copy view crops and view breaks between views?
Place the views on a sheet.  Add detail lines in paper space where you want a break in the view.  Now activate the view and eyeball the breaks.  You can nudge your break annotation line/mask using your arrow keys to get the break line visually to line up.  The more you are zoomed in, the smaller the nudge increment.
View "Breaks"
Tue, Mar 5, 2013 at 10:17:52 PM
View Breaks and break lines
Tue, Jun 26, 2012 at 6:49:55 PM
Topography breaks 3D camera views
Thu, Sep 14, 2017 at 7:44:10 AM
View breaks
Mon, Jul 23, 2007 at 1:14:55 PM
Trouble copying detail items from Section View to Drafting View
Mon, Aug 19, 2013 at 1:08:05 PM
Page generation time: 0.7037
