Forums >> Revit Systems >> Technical Support >> HOW TO USE AN ALTERNATIVE CODEC IN REVIT 2009
Sun, Apr 26, 2009 at 5:23:49 PM | HOW TO USE AN ALTERNATIVE CODEC IN REVIT 2009
robert
hi all,
i am using a vista 64bit 2009 revit version
when exporting an avi i only have the choice between four codec versions
i used the intel iyuv.
it works and the avi produced will work ok on the vista machine
but creates problems on other machines.
i was told by my dealer that when i install an other codec, that codec then automaticly becomes available
in the revit dialog box. (i installed divx)
no such luck however
does anybody, including revit know how this can be done
current set up is very poor and the avi's can be guanteed to work on
a clients machine, which is rather embarrassing.
thanks so much,
bob.
Sun, Apr 26, 2009 at 6:48:24 PM | HOW TO USE AN ALTERNATIVE CODEC IN REVIT 2009
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The best approach is to do the compression outside of Revit.  Export out as "Full frames uncompressed", then you can use a wide array of software, some free, to do the compression.  I prefer Camtasia Studio, but you could also use Windows Movie Maker or a number of others...
Regards,
Chris.
Sun, Apr 26, 2009 at 8:38:34 PM | HOW TO USE AN ALTERNATIVE CODEC IN REVIT 2009
robert
thanks mate,
that was a promt responce
very much appreciated
have not tried as yet
robert
2011 Revit Architecture Export Walkthrough CODEC
Tue, May 18, 2010 at 9:43:10 AM
Uncompress Walkthrough Codec Problem
Thu, Aug 13, 2009 at 11:45:50 AM
rendering help please
Thu, Apr 5, 2007 at 12:57:03 AM
Revit MEP 2009 family to be used in Revit Architecture 2009
Fri, Feb 6, 2009 at 8:09:24 AM
Walkthrough problems in Revit 2012 Win 7 64 bit
Thu, Sep 29, 2011 at 6:07:53 PM
Page generation time: 2.6213
