Forums >> Revit Building >> Technical Support >> Scheduling shared parameters of nested famiies?
Sun, Apr 26, 2009 at 5:47:01 AM | Scheduling shared parameters of nested famiies?
snowyweston
I am trying to schedule the properties of nested elements within a host family, I have this panel:
[url]http://i23.photobucket.com/albums/b372/snowyweston/Query-1.jpg[/url]
In which I have loaded (at present generic model) elements (green & blue) that flex accordingly with the change to the Panel Height, Panel Width & Panel Thickness by "pairing" the parameters. Loaded into a project I can schedule the shared parameters set within the host family to get this:
[url]http://i23.photobucket.com/albums/b372/snowyweston/A1.jpg[/url]
Adding a second type of the host family, I then obviously get this:
[url]http://i23.photobucket.com/albums/b372/snowyweston/00.jpg[/url]
and that's a good start, but where I am failing is to now schedule the information [i]within[/i] the host family to get at the "green & blue" parameters, ie:
[url]http://i23.photobucket.com/albums/b372/snowyweston/A.jpg[/url]
Which, with the second type of the host family, would/should give me this (in the two different schedules)
[URL]http://i23.photobucket.com/albums/b372/snowyweston/02-3.jpg[/URL]
How do I do this?
[B]And whilst I'm here - how do I get links to work here?[/B]Edited on: Sun, Apr 26, 2009 at 5:51:21 AM
Edited on: Sun, Apr 26, 2009 at 5:52:58 AM
Sun, Apr 26, 2009 at 9:19:41 AM | Scheduling shared parameters of nested famiies?
To post a hot link , in the options of the posting window, you will see a chanin link, highlight the words or an http address and this link option will un-ghost, pick it then enter the address (or paste it).
I didn't look at your links but just a sa guess, did you set the nested family to "shared"?  You must do that in the family editor before you load the family.  Under options.
Sun, Apr 26, 2009 at 1:51:08 PM | Scheduling shared parameters of nested famiies?
snowyweston
I just had a look at that method - unless I'm mistaken it would appear this forum doesn't support image placement within posts - which (if the case) is a great shame as images illustrate ideas so much easier....
As for setting the nested family to "shared" - is this in the "family categories" section? I'll have a look at it tomorrow - it's too nice outside to sit at my computer.
Sun, Apr 26, 2009 at 1:56:12 PM | Scheduling shared parameters of nested famiies?
You can place images ... attach - must be < 2Mb
Setting is withing the nested family, not host - uders settings/family types and parameters
Door parameters not scheduling or tagging in double door.
Mon, Sep 26, 2011 at 3:29:50 PM
Scheduling Door Material with yes/no Paramters
Fri, Dec 16, 2011 at 10:24:05 AM
Creating nested Family Parameters
Fri, Jun 26, 2015 at 3:52:28 AM
Shared Parameters
Tue, Nov 10, 2015 at 2:11:20 PM
Nesting Shared Families [ 1 2 ]
Thu, Oct 15, 2015 at 1:17:47 PM
16
Page generation time: 0.1950
