Forums >> Revit Building >> Technical Support >> Site curb work
Tue, Jul 12, 2005 at 11:27:05 AM | Site curb work
Surfrusty
What's the best way to create the curbs on a site plan?
Tue, Jul 12, 2005 at 4:44:21 PM | RE: Site curb work
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If its flat or a simple slope then use slab edges. If complicated falls then there is no easy way and will have to resort to in-place families with various sweeps.
Tue, Jul 12, 2005 at 6:05:08 PM | RE: Site curb work
Surfrusty
Thanks for the input. Surfrusty
Wed, Oct 10, 2007 at 2:34:01 PM | Site curb work
christinea
Heres another way that i found.....works great!!!!
1. create your topo surface as you usually would
2. draw a reference line at your edge of curb. this line will make it extremely easy to create everything using offsets
3. select 'split surface' and separate your different areas (grass, curb, gutter, road) this is made simple by selecting the reference line each time and hitting tab to select all. offset the line as needed to make the correct size curb, gutter, exc.
4. to create the vertical curb edge, do another 'split surface' on either side of the original curb line. the split surfaces will need to be 1/2" offset each side. this will create the top and bottom of the vertical surface.
5. in elevation view, move the road, curb, and one of the two 1/2" down 6"
6. you now have a 1/2" wide surface at elev. 0 and a 1/2" wide surface at elev -6
7. click the 'merge surfaces' button, select the lower 1/2" split surface, and the upper 1/2" splite surface. this creates the vertical.
 Hope this helps Christine
Mon, Aug 25, 2008 at 12:54:00 PM | Site curb work
jmqrsq
5 Stars: 3 Votes
christinea, if you would be so kind to post some in process pics of what you suggest it would help me to understand this better. That is if you are still bouncing around these forums. Thanks
How do I make curb
Wed, Dec 14, 2011 at 3:57:42 PM
Line Based Curb family
Thu, Nov 8, 2007 at 10:02:28 AM
how to add elevation to curb sweeps?
Fri, Feb 4, 2011 at 3:54:40 PM
Creating curb that conforms to a topography
Sat, Jun 2, 2012 at 9:15:31 AM
14
Help! Wanting to attach a curb sweep to a site "floor" family.
Wed, Oct 24, 2007 at 1:47:29 PM
Page generation time: 1.1641
