Forums >> Revit Building >> Technical Support >> import dwg to revit but cant underlay
Sun, Apr 26, 2009 at 4:11:04 AM | import dwg to revit but cant underlay
grant7
Hi!
I figure the best way to get my dwg into revit is to import onto level 1 - then underlay from level 2 and trace over top.
But no matter what after import underlay from other levels will not work (view level 1) at all??
Any ideas pse - Also if theres a better way to get my dwg in revit would love to hear...  Revit 2009
Thanks
Grant
Sun, Apr 26, 2009 at 5:24:18 AM | import dwg to revit but cant underlay
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
i've been asking about importing DWG all day long
and i don't think many know about doing this..
but there are a lot of useful things you can do with
DWG lines in revit.. they sure are tricky though..
not sure what you mean about underlay because
those lines don't cut.. but you can make them
halftone in VV in the import catagories tab..
check out the mess of DWG lines i'm dealing
with- LOL
Importing dwg as underlay
Sun, May 24, 2020 at 10:56:19 PM
REVIT 2015 - Underlay: EXPORT?
Tue, Aug 5, 2014 at 2:54:54 PM
Import DWG problem with size
Mon, Dec 6, 2010 at 7:33:32 PM
Can't import dwg or dxf to RS2008
Wed, May 30, 2007 at 10:36:07 PM
not to see imported dwg on every level (after importing dwg)
Sun, Nov 26, 2006 at 11:13:58 PM
Page generation time: 3.2590
