Forums >> Revit Building >> Technical Support >> DWG import shaded colors
Sat, Apr 25, 2009 at 8:36:00 PM | DWG import shaded colors
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
simply import this DXF wireframe 3D model and
let it place on the first level.. look at it in 3D view..
in shaded line view the whole thing is orange..
i want to make it transparent so all i see is
lines for the DXF and shaded colors for the
elements i place in and around those lines..
in the imported catagories there are two color render
numbers but changing those to transparent or
any other color does nothing..
try it and see if you can get the color off
or transparent in a shaded line view and
win a cookie..
Sun, Apr 26, 2009 at 1:53:03 PM | DWG import shaded colors
Missing the file.....
Export Linework colors to DWG
Wed, Sep 14, 2016 at 12:04:12 AM
Import DWG problem with size
Mon, Dec 6, 2010 at 7:33:32 PM
Can't import dwg or dxf to RS2008
Wed, May 30, 2007 at 10:36:07 PM
Revit 2009 - import Dunn Edwards paint colors?
Wed, Sep 14, 2011 at 5:19:49 PM
12
autocad layers change color when imported into revit
Fri, Oct 2, 2020 at 5:31:59 AM
Page generation time: 1.8392
