22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Newbie needs help
2 Posts No Rating |
Hi guys. I'm a newbie and need a bit of help. I wanna know how to split a wall down it's core or any tips how to allocate 2 colours to a wall (interior & exterior). I'm using 79mm partion wall. Any ideas?????
If you use a wall with layers, you can assign different materials and colors to each of the interior and exterior finish layers. On the exterior for example you may have stucco and you can assign this layer a material. On the interior if you have wall board you can also assign that a material. If you have two colors of the same material it gets a bit more tricky. You could have different wall types for each of the different colors of materials, or you can use the Revit paint tool to simply paint a wall a different color. If you only want a region of a wall a different color, then using the split face tool in conjuntion with the paint tool may be the best answer.
The methodology you employ will depend on what the final result you want is. If all you are looking to do is make somethng look correct for rendering purposes the paint method will work fine. If you want to get an accurate schedule of each finish type, then you will have to use the full modeling method.
HTH
Tom
2 Posts No Rating |
Thanks a lot bud. Quite simple when you look at it in those terms but only once YOU said it. Much appreciated.
Ciao!
You could also make a wall type with the core out of two layers side by side. it would look like one layer if it was the same color, but just make one layer a different color/material..
This thread has almost 4 years old.
LOL.......jul 2005.
Newbie |
Thu, Apr 27, 2017 at 9:35:53 AM
Revit MEP 2008 Newbie! |
Mon, Oct 1, 2007 at 10:00:09 AM
newbie from ohio |
Sat, Jan 2, 2010 at 8:16:07 AM
newbie.. |
Sun, Nov 28, 2010 at 2:33:02 AM
Community Newbie :) |
Thu, Mar 10, 2016 at 2:53:52 PM
