9 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> House and Detached Garage Revit 2009
What is the best way to draw a house and also a detached garage that is at an angle to the house on the plot. If I draw the garage at say 25 degrees to the house then all its dimensioning will be at 25 degrees. There must be a simple answer Cheers Mark
You can rotate the view of the garage. From within that view, turn on the crop regions, pick that and then the rotate command, you can now rotate the view to the angle you want and it will not rotate the model elements.
BTW , this is all explained very well in the HELP. Learn to use the search in HELP. If you had entered rotate, you will find a topic on rotating a view.
Thank you, I must say I do shy away from the HELP as this forum is so good. I must try better. Thanks again. Mark
inserting floor plan into sheet |
Tue, Feb 28, 2006 at 7:01:10 PM
Exterior and interior walls |
Tue, Apr 28, 2009 at 9:57:30 AM
How Do I Create A Lean To Roof Over A Garage |
Thu, Jan 15, 2009 at 3:31:31 PM
12
taking an elevation of a linked model |
Tue, Mar 4, 2014 at 11:57:16 AM
Area Plan - merge or combine areas? |
Mon, Sep 9, 2013 at 4:32:00 PM
