29 Users Online (27 Members):
Forums >> Revit Structure >> Technical Support >> truss not visible on framing plan
9 Posts No Rating |
I installed a Warren truss attached to roof. It is visible in elevation, section, and 3d. When you hover over the line on the plan it appears, but it is not visible when I am looking at the roof framing plan. I have checked the view range and it appears to be correct.
is it showing as just linework? I am not familiar with the family you are using but perhaps changing the detail level from coarse to fine may do the trick?
9 Posts No Rating |
I want my view on course. I want the joists, beams and trusses to show as a single line. If I change to fine, the truss is visible but it shows multiple lines for the truss. Don't understand why beams and joists are ok and not the truss.
post a copy of the truss family you are using.
9 Posts No Rating |
Here is the truss family.
Grey out Truss |
Thu, Jan 5, 2006 at 10:04:52 PM
Revit 2012 Truss System (framing members not showing) |
Wed, May 9, 2012 at 9:25:33 AM
Framing Plan Objects Visiblity (2008) |
Wed, Oct 17, 2007 at 6:21:04 PM
Members of the truss are not visible after rendering |
Sat, Jun 1, 2013 at 11:01:30 PM
roof truss install |
Tue, Feb 10, 2009 at 9:00:56 PM
12
