31 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> Revit 2010 Keynoting
10 Posts No Rating |
BE AWARE! Before replacing your kenoting file, you should know that it is no longer a simple replacement procedure. The new keynoting file for 2010 has a new path "ribbon" instead of "menu" and will need to be edited before being replaced. Otherwise you will have no keyboard commands at all.
6 Posts No Rating |
My keynoting function in Revit 2010 is not working properly after I modified the keynote file. I added some catagories into "RevitKeynotes_Imperial_2004.txt" file, save as another file "Imperial_2004-1.txt" and put it in the same folder. I tried to delete the 2004.txt but failed, then I associated my project with 2004-1.txt. When I chose "keynote number - boxed - small" option, it showed text instead of box and number; even after I associated back to the original file 2004.txt and deleted the new file 2004-1.txt I created, it is still the same. Do you have any idea how to fix it?
Revit 2010 - Keynoting dependent plans |
Tue, Jan 5, 2010 at 10:48:39 AM
Keynoting WHAT TO DO? Revit 2010 |
Mon, Apr 5, 2010 at 3:46:31 PM
Keynoting |
Tue, Aug 28, 2007 at 4:28:31 PM
keynoting missing after download of subscription pack |
Mon, Apr 19, 2010 at 9:17:13 AM
KEYNOTING!!! |
Thu, Mar 17, 2011 at 2:16:59 PM
