Forums >> Revit Building >> Technical Support >> locking height of family to ceiling height?
Fri, Apr 24, 2009 at 12:21:50 PM | locking height of family to ceiling height?
jhendershot
I am building a family that is vertical that will be locked a certain distance off the finished floor. the height of said object i want to be locked to whatever the ceiling height would be. is there a way to do this within the family for the length specified in the formula to use the height of the ceiling in the room?
or any other ideas to auto adjust the height of the object to match that of the ceiling height would be appreciated.
thanks.
j.
Mon, Apr 27, 2009 at 5:29:03 AM | locking height of family to ceiling height?
robinballew
robinballew Avatar
3 Stars: 4 Votes
The only way to get Revit to jump to the ceiling is to make the family ceiling based. I think what you want is to make the family's height an Instance Parameter. When you stretch the family to the ceiling you can "lock" it in the project.
BallewDesigns.com
Ceiling height column problem in schedules
Fri, Dec 7, 2007 at 10:23:16 AM
Room Name w/ manually entered Ceiling Height
Mon, Jan 19, 2009 at 3:50:30 PM
Add Ceiling Height in Room Schedule
Mon, Nov 19, 2012 at 9:38:54 AM
Ceiling height in Room Schedule
Sun, Apr 5, 2009 at 12:44:47 PM
Room schedule with ceiling height
Thu, Jan 18, 2007 at 3:46:21 PM
Page generation time: 1.3093
