15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Revit 2008 - Plots take forever or just hang
I am using Revit Architecture 2008 on the first Revit project in our office. Here's my station spec: Dell Inc. Inspiron 5302.33 gigahertz Intel Core2 Duo64 kilobyte primary memory cache4096 kilobyte secondary memory cacheBus Clock: 333 megahertzBIOS: Dell Inc. 1.0.3 07/12/20073328 Megabytes Installed Memory We have a 10/100 network that is error free (for the time being). I am trying to plot a couple of 30"x42" sheets with floor plans and one 3D view on a HP DesignJet 1055CM (with RAM 64+64 MB and hard disk: 3102MB). The Revit file size is 14 MB. The plots are taking forever (30 minutes +), or the plotter just hangs. I am using "Normal" quality and have tried processing "In printer" and "In computer" which produce the same results. I also tried to plot to PDF and the Acrobat Distiller crashed, even with it set to "smallest file size". I plotted 11"x17" to HP Color LaserJet 5500 (352 MB memory) and HP LaserJet 5000 (164 MB memory) and both came out fine, though the HP 5000 printed a filled region a bit strangely. We don't usually have problems in other software with the HP 1055, though it does take a while on some large presentation files, but that's to be expected. Any thoughts or suggestions will be greatly appreciated.
How many Linked DWG (AutoCad) files do you have? How many "model lines" do you have? Do you have the Shadow's on? Did you try Raster printing, not Vector..
----------------------------------- BallewDesigns.com |
136 Posts No Rating |
did you ever resolve this issue? I am plotting from RAC2010 to an HP1055 as well, and the sheets (34x44) are printing slower than i have ever seen a 1055 plot; and they are just floor plans with some filled regions. I printed a half size set of the same file last night without any issues.
I'd rather be riding at whistler. or highland. thats good too.
First, make sure you have shadows turned off, Revit struggles with that. as well, make sure you are using Vector processing in your printer settings, Raster will move a lot of data to the printer and can take forever.
Thanks eldados, but that those were some of the first things i double checked when i realized i had a problem. it seems to only be happening on sheets that have building sections, but only at certain times. I am suspecting now some issue with the queue on the print server.
in that case I will check the printer drivers and make sure you have the current ones. as well send the same print to another printer, if it does print in a normal time, you know it's the printer's drivers... Do you get the same issues when you print to PDF?
I found that one of my linked DWG files was causing most of the problem, and the DWG file wasn't that large. Revit didn't like something about it I guess. Once I narrowed it down and unlinked that file it got much better, though it still takes 2 or 3 times longer than any plot ever did with AutoCad.
REVIT MEP Halftone ducts |
Thu, Apr 30, 2009 at 9:03:54 AM
Plotting |
Fri, Oct 17, 2008 at 9:01:12 AM
Printing with Shadows taking forever! |
Thu, Jan 24, 2008 at 1:07:33 PM
Sheet title block plots incorrectly |
Wed, Nov 3, 2010 at 10:44:30 AM
Dropped lines on plots |
Tue, Mar 30, 2004 at 2:45:58 PM
