10 Users Online (8 Members):
Forums >> Revit Structure >> Technical Support >> Walls Below Visability
44 Posts No Rating |
I am coming across an issue to where I have two walls with the exact same properties (i.e. base constraint, top constraint, offsets, type, etc.) that are showing up differently on plan. Both of these walls stop below an elevated slab at the exact same elevation. One of the walls shows up dashed like it is supposed to, but the other shows up as solid lines. Has anybody else ran into this or know a remedy for it? It does not make any sense to me. Thanks in advance. Mike
Sorry, but something is not the same ... Phase? Wall attached to floor? Did you show the one wall as hidden by using the show hidden lines and picking it?
They are the same phase and neither are attached to floor. I have never used the "show hidden lines" command before so that is not it. I am totally confused.
Attached are some screen shots of the walls I am talking about. There is a plan view and then the Element Properties Box for each wall. This is very frustrating.
37 Posts No Rating |
Have you joined one of the walls with the floor (not attached)?
Is there a graphics override on one of them?
----------------------------------- Chatting it up on gmail - travistlo.j@gmail.com |
check you discipline, its simce that you have walls under Structure discipline and the other with architecture discipline. Put them under the same discipline. let me know if this fix your problem.
Visability parameter for dimensions |
Tue, Jul 31, 2012 at 12:17:05 PM
Visability/ graphics |
Tue, Mar 25, 2008 at 1:40:47 PM
visability problems |
Thu, Feb 1, 2007 at 6:57:59 PM
Tue, Jan 30, 2007 at 10:44:00 PM
Exception in Visability Graphs |
Mon, Aug 6, 2012 at 8:05:59 AM
