Forums >> Revit Building >> Technical Support >> Wall connection issue when wall are not drawn at the same time
Fri, Apr 24, 2009 at 9:33:18 AM | Wall connection issue when wall are not drawn at the same time
architurk
architurk Avatar
3.5 Stars: 3 Votes
When two walls are NOT drawns at the same time (even though their location line is the same), they connect quite nice in plan (PLAN), but there usually appears an unnecessary line in 3d view (3D). I can only get rid of this line by "edit wall joins/mitter", but it doesnt seem a noble way (cause plan view changes this time)
When I draw those same walls at the same sequence, there is no problem.
Is there a way to avoid this, or cure this (other than wall joins)?
ps: I am sorry if the question appeared in the forum before, but I guess it would take really long time to look for it, since keywords for this question seemed quite general.
ps2: (to the site moderators) This is such a nice forum to share ideas but I guess it would be better I guess to have more classified questions under more classified headlines (such as walls, floors, families etc) and I guess It would be nice to narrow search tool into some other categories, cause whenever I make a research there it comes a lot of headlines generally not related with what i am looking for!
 ps3: I use RA2009
Fri, Apr 24, 2009 at 10:12:39 AM | Wall connection issue when wall are not drawn at the same time
This never happens to me no matter how I place my walls.  Can we see a screenshot of your wall settings?
Mon, Apr 27, 2009 at 3:37:09 AM | Wall connection issue when wall are not drawn at the same time
architurk
architurk Avatar
3.5 Stars: 3 Votes
I send the screenshot and the rvt file as well
Mon, Apr 27, 2009 at 7:20:47 AM | Wall connection issue when wall are not drawn at the same time
cercas
5 Stars: 3 Votes
Strutural use of the wall, is as shear.... , if you change it, it will appear correct...
If that is realy the use you want to give to wall, them you should use the wall join tool, and set it to mitter....
 Winking
Joao Cercas
On Revit 2010 (SP3)
Mon, Apr 27, 2009 at 8:33:21 AM | Wall connection issue when wall are not drawn at the same time
architurk
architurk Avatar
3.5 Stars: 3 Votes
Thank you Cercas!
One thing is strange though; free from the component of wall, when the "structural usage" is changed to anything (other than "non-bearing"Winking it fixes the situation. I wonder is it a bug or something? Cause I cant understand the mentality behind?
Wall Connection Issue
Thu, Jul 11, 2013 at 12:00:25 PM
The connection between wall and floor
Fri, May 14, 2010 at 8:43:26 AM
Wall and floor connection/cut
Tue, May 8, 2012 at 3:43:26 PM
wall connection issue
Fri, Apr 24, 2009 at 9:20:04 AM
wall sweep on a wall with a custom profile
Wed, Dec 2, 2009 at 5:48:07 PM
Page generation time: 1.7876
