Forums >> Revit Building >> Technical Support >> revit 2010 problem(s)
Thu, Apr 23, 2009 at 12:02:09 PM | revit 2010 problem(s)
barcardi
no its not UI related.  anyhow
1: View range is broken, i have some 2x4s modeled in above my doors, windows, etc and they, as well as a lot of other things, are now appearing that were not in the view range before.  The default is the same: 4' to 7'6,"  is there any workaround for this?
2: how the heck do you linear dimension in elevation? it only lets me dimension horizontally not vertically?  this one is important, if anyone knows please let me know
Thu, Apr 23, 2009 at 1:02:08 PM | revit 2010 problem(s)
afc4
3 Stars: 3 Votes
To answer your second question use Aligned dimensions to go vertically.
Revit 2010 to 3ds Max 2010 Problem
Thu, Jul 30, 2009 at 9:31:25 AM
RSA 2010 problem
Thu, Apr 23, 2009 at 1:13:37 AM
Revit 2010 Dwg. Import problem
Thu, Sep 2, 2010 at 1:52:03 AM
Revit 2010 UI Problem
Wed, Jan 13, 2010 at 1:45:49 PM
Problem with Revit 2010 save file format?
Wed, Aug 12, 2009 at 9:24:58 PM
Page generation time: 1.8064
