Forums >> Revit Building >> Technical Support >> Revit 2009 Simple stair, boundary line error
Thu, Apr 23, 2009 at 11:15:33 AM | Revit 2009 Simple stair, boundary line error
beckyl
I am trying to edit an L-shaped stair from a 90 degree turn to an acute 45 degree turn, and every time I try to edit the stair in sketch mode, it gives me the error message that "Stairs require no more than two boundaries." I have tried drawing the stairs from scratch with only risers and boundary lines, as well as with the run command, but either way Revit will not allow me to draw the stair with the angle I want.
Thu, Apr 23, 2009 at 11:30:21 AM | Revit 2009 Simple stair, boundary line error
I just did one from scratch using the run command ... pulled up to a landing then turned an angle ... I missed the crner so I deleted the short side of that landing, then grabbed everything beyond the landing and moved them back so that the two risers pmet at the turn, cleaned up the landing line... all worked.
Simple Stair Nosing error
Thu, Mar 5, 2015 at 9:15:24 PM
stair boundary
Mon, May 16, 2016 at 4:51:31 AM
2009-Stair Error
Thu, Jun 25, 2009 at 5:55:09 AM
Stair by boundary - stair direction
Mon, Aug 2, 2010 at 8:27:29 AM
Stair and 2 odd shaped landings
Wed, Feb 11, 2009 at 3:16:45 PM
Page generation time: 1.9519
