Forums >> Revit Building >> Technical Support >> Pro-E to Revit 2010???
Wed, Apr 22, 2009 at 7:07:44 PM | Pro-E to Revit 2010???
CKorleski
I have a client that I am working with on a current project that works with Pro-E only.  My firm uses Revit ( structure & MEP 2010), my question is there a file format that will be compatable with Revit coming from Pro-E?  I am not looking for any information stored in the Pro-E model, basically a large block would work for what I need.  Thanks
Tue, Apr 28, 2009 at 11:41:11 AM | Pro-E to Revit 2010???
CKorleski
Well after a week of searching for an answer I have come up empty handed.  But I think I may have found a solution, does anyone here know if there is a way to take a file from 3ds Max and bring it into Revit?  I found a file type that will work in 3ds Max from Pro-E, but now I need to get it from 3ds Max into Revit...
Tue, Apr 28, 2009 at 11:48:08 AM | Pro-E to Revit 2010???
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I thought Pro-E supported IFC? If not it should or else your going to have to export from max to dwg
Tue, Apr 28, 2009 at 12:14:30 PM | Pro-E to Revit 2010???
CKorleski
My client never mentioned the IFC file type, the file types that I was told they could export as were, SET, STEP, AI, CGM, IGES, VDA, STL, VRML, and ACIS.  There may be more file types out there.  I don't know a whole lot about Pro-E, this was just what I was given...
Mon, Nov 30, 2009 at 12:13:01 PM | Pro-E to Revit 2010???
DiVenti
Please let me know if you found an anser to this. I also looking into exporting from Pro/Engineer to Revit. What format do you Revit guys can import as far as neutral files? IGES, SAT/ACIS, NEU, X_T? We can't export in 3D DWG.
DiVenti
Mon, Nov 30, 2009 at 12:35:28 PM | Pro-E to Revit 2010???
alabaster2513
3.5 Stars: 25 Votes
ACIS SAT files are available for import using Revit
Mon, Nov 30, 2009 at 12:59:14 PM | Pro-E to Revit 2010???
DiVenti
Did anybody actually tried to import an SAT file into Revit. I want to find the "right" way to export 3D models from Pro/Engineer to Revit BIM 2009/2010.
DiVenti
Apple MacBook Pro for sale with Revit 2010
Mon, Aug 24, 2009 at 2:18:56 PM
revit structure to cbs pro
Sat, Dec 24, 2016 at 5:13:28 AM
Autodesk Robo structural analysic pro 2010 with window7
Sun, Aug 2, 2009 at 11:23:21 PM
Revit architecture for Macbook pro? [ 1 2 3 ]
Thu, Oct 27, 2011 at 7:25:35 AM
39
Revit architecture on Macbook pro i7 with flashdrive7??
Wed, Oct 19, 2011 at 5:11:22 PM
Page generation time: 2.1646
