Forums >> Revit Building >> Technical Support >> Revit 2010 UI Problem
Wed, Apr 22, 2009 at 8:01:37 AM | Revit 2010 UI Problem
danpecor
danpecor Avatar
Just wondering if anybody else has had this problem since installing Revit 2010.
- When first opened, there is a small toolbar in the middle of the screen (see Screenshot 1).  It looks like the old AutoCAD toolbars, and like a new one created before buttons are dragged to it.
- When the toolbar is left alone, the ribbon menu works fine.  Note the "Element" panel of the ribbon is displayed (see Screenshot 2).
- When the toolbar is closed (clicking the red X), the "Element" panel of the ribbon is no longer available (see Screenshot 3).  This is the case for all elements.
Any explanations and/or solutions would be much appreciated.  Thank you
57554_Revit_2010_Screenshot_1.jpg57554_Revit_2010_Screenshot_2.jpg57554_Revit_2010_Screenshot_3.jpg
Wed, Apr 22, 2009 at 1:33:22 PM | Revit 2010 UI Problem
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Here try this
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=13126319&linkID=9243099
Wed, Apr 22, 2009 at 4:58:01 PM | Revit 2010 UI Problem
danpecor
danpecor Avatar
No, that did not fix the problem.  Thank you anyway for trying.
Wed, Apr 22, 2009 at 5:28:49 PM | Revit 2010 UI Problem
alabaster2513
3.5 Stars: 25 Votes
hmmm my only other advise would be to uninstall and reinstall or send a support request through the subscription center and provide them with a journal file for 2010
Thu, Apr 23, 2009 at 10:19:35 AM | Revit 2010 UI Problem
danpecor
danpecor Avatar
I like talking to myself, so I thought I would reply to my own post Smile
Actually a support request was submitted to Autodesk and their reply was that some display managers for certain video cards such as nVidia and ATI, have been known to cause this problem.  In my case, disabling the nView Desktop Manager cleared the problem up.
Just wanted to give a heads up to anyone who may have the same problem.
Wed, Jan 13, 2010 at 1:45:49 PM | Revit 2010 UI Problem
shadow7
Thanks for the heads up....I had the same problem.
Revit 2010 to 3ds Max 2010 Problem
Thu, Jul 30, 2009 at 9:31:25 AM
RSA 2010 problem
Thu, Apr 23, 2009 at 1:13:37 AM
Revit 2010 Dwg. Import problem
Thu, Sep 2, 2010 at 1:52:03 AM
Problem with Revit 2010 save file format?
Wed, Aug 12, 2009 at 9:24:58 PM
Revit 2010 Memory reaching critical limit
Mon, Aug 31, 2009 at 11:35:39 PM
Page generation time: 1.7016
