8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Removing individual vindowsegments from a curtainwall?
13 Posts No Rating |
Hi Guys again Now i have a problem with deleting individual glass segments from my curtain wall. I simply cannot press delete to remove them. Does anybody know how? Kind Regards Peter Gade
Which components do you want to remove? You can delete mullions - you can replace the panel with an empty system panel ... you can edit the profile of the curtain-wall and sketch a hole in it of any shape.
it doesnt seems to let me chance individual panels. It wants to chance the whole deal?
You have placed a fully automatic curtainwall.... all of the controls are setup in the type. Setup a curtainwall to one that is not automatic ... turn off the spacings/mullion and panel types / etc. then change this curtainwall to that type and pick the option that keeps all the components in place.... now you can change individual elements.
I got i thanks m8
Curtainwall edit profile |
Fri, Jun 12, 2020 at 7:48:21 AM
Converting curtainwall into wireframe |
Wed, Jun 13, 2012 at 2:08:44 PM
12
Revit 2013 - Can't Use Align Tool on Edge of Curtainwall |
Fri, Oct 26, 2012 at 11:45:05 AM
Custom Curtainwall Tag from View Tag |
Tue, Feb 26, 2008 at 9:17:54 AM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing |
Mon, Jan 19, 2015 at 7:41:36 AM
