Forums >> Revit Building >> Technical Support >> Centering glazing in a Storefront
Wed, Apr 22, 2009 at 7:19:11 AM | Centering glazing in a Storefront
mtelford
5 Stars: 7 Votes
I'm trying to align the center of the glass with the center of the mullions.  I know it's possible, but i can't find it in the Element Properties.
Wed, Apr 22, 2009 at 12:42:39 PM | Centering glazing in a Storefront
PeteGGA
Tab until you can select the glass panel, unpin the panel, then go into element properties of the glass panel, there will be an offset dimension in the type properties, adjust the dimension to work with your mullion size.
window / storefront schedule,
Thu, Sep 10, 2009 at 1:02:39 PM
Phasing for storefront system panel
Wed, May 18, 2011 at 7:44:36 AM
When to use curtain wall vs. storefront vs. window glazing
Fri, Sep 11, 2009 at 3:00:02 PM
Problems with selecting mullion on curtain grid
Wed, Jun 11, 2014 at 10:13:11 AM
Storefront Wall needs Storefront Doors
Mon, Dec 3, 2007 at 8:58:52 AM
Page generation time: 0.0703
