Forums >> Revit Building >> Technical Support >> Short walls not cutting??
Wed, Apr 22, 2009 at 5:43:10 AM | Short walls not cutting??
DaveF
HiI vaguely remember reading something about this, but not sure I’ve got it correct.Hope you can clarify it for me.Is it true that walls under two foot won’t cut even if the view range is set within the two feet?CheersDave F.
Wed, Apr 22, 2009 at 6:52:08 AM | Short walls not cutting??
I don't know if I have this all straight in my head either because it's been awhile since I had this problem but you are somewhat correct.  I found that moving the bottom limits of your view range (down) you could get the view right.  Play with those numbers and see what happens.
short walls+phases problematic
Fri, Dec 16, 2005 at 7:15:16 PM
Window not cutting furred wall
Tue, Feb 14, 2012 at 12:56:04 PM
Windows not cutting through walls
Mon, Nov 21, 2016 at 9:37:41 AM
Problem: Gutters / Cutting Walls and Roofs (not footprint)
Thu, Jul 18, 2013 at 7:07:41 AM
Can't figure it out, Windows are not cutting my walls
Fri, Apr 30, 2010 at 12:39:16 PM
Page generation time: 1.6852
