Forums >> Revit Building >> Technical Support >> converting files for use between cad programs
Tue, Apr 21, 2009 at 9:01:13 PM | converting files for use between cad programs
whitehamish
Hey everyone
I am doing a project at the moment where I have to model some appliances and upload them to a clients website for download.
they want the downloads in file formats so that they can be used in Archicad, Autocad, Microstation, Vector works etc. I have
been looking into IFC conversions but when ever I go to use it the icon is dull grey and not usable. Will I then have to go into
these programs to convert the drawings to their specific family or library part file extension or can I do if from elsewhere
, does anyone have any tips on how to use this? Also what is the best format for the files to be used in Autocad as famalies?
sorry If my questions are a bit unclear. i am a bit unclear on it all myself
thanks in advance
Mon, Apr 27, 2009 at 3:57:23 PM | converting files for use between cad programs
travistlo
5 Stars: 2 Votes
Are you trying to export to IFC within the family file? I dont think that you can export a single family to and IFC file format. I think revit wants you to export the project.
You might have to actually create the items in each program to get full functionality from them. (instead of importing the exported revit model). You can probably use the export as a base, but might have to redraw/model some things.
Chatting it up on gmail - travistlo.j@gmail.com
Mon, Apr 27, 2009 at 4:15:55 PM | converting files for use between cad programs
There is no method to do what you want...sorry.  Each program you state has it's own unique rules.  You can't even go from AutoCAD to REVIT or vica versa and preserve any of the parametrics that might be built into families/blocks and both of those programs come from AutoDESK.
Through IFC, you can exchange much of the overall project data.
Thu, Apr 30, 2009 at 12:39:03 AM | converting files for use between cad programs
whitehamish
curse
A bit frustrating huh, thanks for the help
Hamish
Converting .skp files to .rfa?
Fri, Jun 25, 2010 at 3:05:23 AM
Custom Library - Typical Details
Fri, Jun 24, 2011 at 1:10:55 PM
Converting DWG materials to Revit Materials
Thu, Sep 13, 2012 at 3:50:29 AM
Converting Revit files to AutoCAD files
Wed, Sep 15, 2010 at 2:09:17 PM
Converting Revit to Bentley
Fri, Aug 22, 2008 at 10:52:38 AM
Page generation time: 2.0095
