Forums >> Revit Building >> Technical Support >> How Do I Cut Out Part Of The Wall?
Tue, Apr 21, 2009 at 7:22:25 PM | How Do I Cut Out Part Of The Wall?
ksmith
I need to cut out some of the wall on the front elevation of a house I want to design but I am not sure how to do this. I want the wall to kind of step up in height over a garage from the end of the building.
Just don't know how to cut the pattern out.
All help appreciated and an image if it helps of the wall I want to cut the pattern in.
Thanks
Kirk
Edited on: Tue, Apr 21, 2009 at 7:25:56 PM
USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes.
Wed, Apr 22, 2009 at 7:20:06 AM | How Do I Cut Out Part Of The Wall?
Click on the wall in plan or elevation and choose "edit profile" from your options bar.
Wed, Apr 22, 2009 at 5:30:18 PM | How Do I Cut Out Part Of The Wall?
ksmith
I've learned how to do that now
Thank you
Edited on: Wed, Apr 22, 2009 at 5:38:28 PM
How to trim a small part from a wall
Tue, Aug 3, 2010 at 12:58:22 PM
Roof/wall join: Cut roof
Tue, Apr 27, 2010 at 7:53:13 AM
Windows just will not cut out properly!!!!
Fri, Mar 1, 2013 at 7:34:42 AM
How to turn part into wall?
Wed, Oct 31, 2012 at 3:24:51 PM
Diagonal End of Wall - Void + Cut Geometry not working
Fri, Aug 30, 2013 at 3:25:08 AM
Page generation time: 1.9056
