Forums >> Revit Building >> Technical Support >> True and Project north
Tue, Apr 21, 2009 at 5:39:44 PM | True and Project north
Darko
1 Stars: 1 Votes
I linked in a revit site model and moved and rotated my entire project to align with the true north location.  I then went to my typical floor plan view and under "tools" rotated the model to project north.
After establishing my true and project north, and verifying it's views in site and typical floor plan, everything seemed correct.
 However, after unloading my site plan, and relinking it in, the locations no longer aligned and it seemed like that origin rotated when i set my project north.
The reason I unlinked and relinked my site plan is because another team will be linking a model in with mine, and i wanted to verify that the locations would be correct.
 what am I missing/doing wrong?
Wed, Apr 22, 2009 at 7:38:42 AM | True and Project north
Look in your H E L P at publishing and acquiring coordinates.
True North vs Project North Linked dwgs
Thu, Mar 10, 2016 at 10:02:26 AM
How to Rotate True North without rotating the whole Project?
Thu, Mar 18, 2010 at 7:25:35 PM
project north/true north
Thu, Mar 17, 2005 at 5:00:19 PM
True North / Project North spelled out
Sun, Jun 10, 2012 at 1:41:04 PM
Project North doesn't rotate back after changed to True North
Fri, May 7, 2010 at 3:24:14 AM
Page generation time: 2.7861
