17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Interior elevations refrencing multiple elevations AND refrence other elevations
Working in 2009 on bathroom elevations. I have a mens and womens back to back. I have an interior elevation in the mens with two refrenced views. The fixture wall then the back wall with the remaining grab bars for the ADA stall. Can I have the elevation in the womens show their fixture wall and then in the other view refrence the drawing from the ADA grab bars in the mens stall, Can I do it with the same elevation marker or do I need to put in another stand alone elevation for the back wall.
I don't believe you can combine them so: Don't just check the elevation box from an interior elevation callout - start a new interior elevation and use the reference other view option. If your views are on the same sheet, you can drag your referenced view callout overtop the normal view...
Problem with Interior elevations |
Fri, Feb 13, 2015 at 1:51:29 PM
interior elevations |
Sat, May 2, 2009 at 11:28:06 AM
Interior Elevations Referencing Detail Numbers |
Sat, Oct 13, 2007 at 11:04:39 AM
Getting door elevations |
Thu, Nov 21, 2013 at 6:12:08 PM
12
Interior Elevations - 4 callout bubbles combined to single callout bubble? |
Wed, Jul 10, 2013 at 5:08:00 PM
