Forums >> Revit Building >> Technical Support >> Creating patterns on floor with design options
Tue, Apr 21, 2009 at 11:36:31 AM | Creating patterns on floor with design options
rm100
Hi.
I am trying to create floor patterns using design options. For some reason,when I try to assign the solid filled region into a particular design option, I get a warning message saying that "some types of elements can;t belong to an Option Set". What am I doing wrong? I need to create different patterns with different colors under different options. How can I do this? I am using Revit 2009.
Thanks for the help in advance.
Tue, Apr 21, 2009 at 11:50:54 AM | Creating patterns on floor with design options
tim123
4 Stars: 19 Votes
Do it in the floor itself.  Create different materials for the floor regions that you require including colour and patterns.  Copy the floor into the design option and split the face and assign the different materials with the paint bucket tool.
Tue, Apr 21, 2009 at 11:52:27 AM | Creating patterns on floor with design options
Design options are for model based elements.  Filled regions are view based.
Create a view for DO one and add your fill -
create another view for DO2 and add the fill to that one.
If you want true model based options, you will need a floor in each option with the appropriate floor finish.
I need to show two interior design options for the same floor. Any ideas?
Wed, May 5, 2010 at 1:22:01 PM
Text In Design Options
Fri, May 28, 2010 at 3:25:07 PM
Design Options?
Wed, May 23, 2007 at 11:59:02 AM
Design options issues
Thu, Mar 2, 2006 at 10:35:31 AM
Hiding an entire floor with Design Options
Thu, May 22, 2008 at 7:39:02 AM
Page generation time: 0.6193
