Forums >> General Discussion >> Wishlist >> Test Labels with psuedo dimension lines
Sun, Jul 10, 2005 at 11:19:47 PM | Test Labels with psuedo dimension lines
riksta
Instead of being able to override dimensions (as in Acad), how about a text label that acts as a dimension, but is separate from the dimensioning system. Text already has the ability to attach leaders, but it would be very handy to be able to attach a dimension line. You could use this if you wanted to indicate the extents of an existing building for example, perhaps on a demolition plan where dimensions may be irrelavent etc, etc, etc. If a psuedo dimension line was included as a text label option (right next to the leader line buttons when placing text), nothing to do with dimensioning, then all you ultra acurate bozo's out there wouldn't have to worry about anyone changing dimension values because it's just a label !!!
Tue, Sep 20, 2005 at 9:45:16 PM | RE: Test Labels with psuedo dimension lines
JAMIER
Revit Structure: I agree, we tend to use text in dimension strings a lot to indicate extents of reinforcing for wall reinforcing or slab reinforcing. It is just another method of annotation which can be used effectivly on plans and/or details.
Fri, Oct 7, 2005 at 4:47:51 PM | RE: Test Labels with psuedo dimension lines
karok
I have found a leader in a family, I would think that a dim with text could be created in a similar way. I will try to create one.
If you have any questions or comments please feel free to contact me. Jason Chamberlain Senler, Campbell and Associates, Inc. jason@senlercampbell.com
MOVE GRID LABELS ON ONLY ONE DRAWING
Sat, Jul 12, 2014 at 1:56:41 PM
Sorry, TEXT LABELS (Idiots can't spell !!!)
Sun, Jul 10, 2005 at 11:21:51 PM
What controls Dimension style of inserted Labels?
Tue, Aug 6, 2013 at 12:37:46 PM
multiple lines in labels
Tue, Aug 18, 2009 at 12:10:18 PM
ref lines and dim extension lines
Wed, Aug 20, 2008 at 7:27:34 AM
Page generation time: 1.2921
