Forums >> Revit Systems >> Technical Support >> 3D Section
Mon, Apr 20, 2009 at 9:42:47 AM | 3D Section
Dix4
Hi!
How can I make a 3D section of my project?
Mon, Apr 20, 2009 at 9:45:49 AM | 3D Section
4 Stars: 205 Votes
What???? did you see in the help Menu??? Section box??? Crop Region??? Far Clip???? I don't know, something like this....
Edited on: Mon, Apr 20, 2009 at 9:48:17 AM
Mon, Apr 20, 2009 at 9:50:46 AM | 3D Section
Dix4
Sorry.... I'm italian.
I want to create a 3D section.
Mon, Apr 20, 2009 at 9:53:28 AM | 3D Section
Dix4
i don't know....
i wont to make a section of my project thaht cut the first level in a place, the secondo in an other.... etc....
in italian is an "split"
Mon, Apr 20, 2009 at 9:55:16 AM | 3D Section
Sorry - I don't believe you can do what you want.
Look in your help at orient to view....
Edited on: Mon, Apr 20, 2009 at 9:57:54 AM
Mon, Apr 20, 2009 at 9:56:13 AM | 3D Section
Dix4
Ok thanks
Edited on: Mon, Apr 20, 2009 at 9:57:20 AM
Sat, May 16, 2009 at 7:23:48 PM | 3D Section
kabcad
Creating a 3D Section in Revit
Have a model created from which you can create a section and 3D view perspective.
  1. Using the default 3D view that is in the project browser create a duplicate of this view.  Select the view then use the secondary mouse button to “Duplicate
  2. Select the new Copy of the view created and using the secondary mouse button rename the view.(ex: 3D Axonometric View)
  3. Go to a plan view to create a new Section for a particular part of the model. (ie: Building  Section, Wall section)
  4. Rename the section (ie: Axonometric Section) in the same manner that the 3D view was renamed.
  5. Make the 3D Axonometric view in the project browser active by double clicking the name in the project browser.
  6. Go to the View pull down menu and select “Orient” → ”To Other View” tool.
  7. Select the name of the section that was just created from the “Orient to Other View” dialogue box.
  8. The new active view will look just like the section view that was created before; the biggest difference will be when you select the “Dynamically Modify View tool” and select the Shift Key and hold down the scroll wheel on your mouse.
  9. This will activate the rotate command and now you will see the section created from an axonometric view perspective.
Section box in Section??
Sat, Dec 10, 2011 at 10:23:01 PM
13
Section tag missing on plan but section still exists
Tue, Nov 22, 2016 at 2:58:15 PM
Section Head with Typical
Tue, Jan 29, 2019 at 8:18:27 PM
Using 2d group for Wall section, section details called out from wall section?
Fri, Oct 9, 2015 at 10:50:56 AM
The option to create Wall section not showing up, only building section.
Wed, Jan 23, 2013 at 3:16:46 PM
Page generation time: 0.2357
