Forums >> Revit Structure >> Technical Support >> Hip roof overbuild framing
Thu, Apr 16, 2009 at 10:42:51 PM | Hip roof overbuild framing
phoulx
I'm stuck on how to accomplish the wood truss framing in an overbuild area- the triangle shaped area in the pic.  I've been using the standard Howe Flat Truss and attaching top chord to the roof which works great in the typical areas but gives me the following errors in the overbuild and in the very short corners:
Revit can not attach to the chosen Roof/Slab.  The truss can not project to a surface or the attachment creates an invalid profile. -and- The current transformation of this specific truss layout will some sub members to overlap.
I imagine the web members can't be created due to the reduced height/length of the truss.  Is there a quick way to place the overbuild members on top of the lower roof?  Then attach top chord?
framing for a hip roof
Mon, Jun 12, 2017 at 2:24:41 PM
Hip Roof Issue
Mon, Mar 24, 2008 at 1:30:08 PM
Partial Hip Roof
Tue, Jun 26, 2007 at 3:22:10 PM
Can't get Gable roof to Join Hip roof
Wed, Aug 20, 2014 at 3:56:33 PM
Problem aligning hip rafter on hip roof exactly where i want it. RAC 2009
Tue, Feb 10, 2009 at 6:37:31 PM
Page generation time: 2.7111
