Forums >> Revit Building >> Technical Support >> Area and Room Tags
Thu, Apr 16, 2009 at 1:38:41 PM | Area and Room Tags
elduderino1234
RAC 2009
My firm is working on a multi-family condo project and we have run into a slight problem. Currently, we have 12 different unit types that are repeated for a total of 63 units. I have already gone ahead and done a rentable area calc for each unit on each floor. In addition, on the overall floor plans, I created area plans for each room in the units but only once. If a unit repeats, rather than dropping in a new room, I just used text to say "Sim. to XX"
Here is where the problem is. Now, we are trying to go through and give each unit a number. In order to do this, I was thinking that each wall inside the unit would be non-room bounding and then just use the room tool to denote the entire unit. I would still like to keep the room seperation lines for the enlarged unit plans and show the different rooms on the enlarged floor plan. What do you guys usually do in this situation? Any help is appreciated. Thanks.
Thu, Apr 16, 2009 at 1:54:04 PM | Area and Room Tags
I hope you are not confusing rooms and areas - you have both and each is definable and can be named.  Use your area designations for your units and keep your rooms - as "rooms".
Thu, Apr 16, 2009 at 1:57:07 PM | Area and Room Tags
elduderino1234
No no, not confusing rooms and areas. I want to be able have an overall room inside the unit (to define the unit type and number) as well as individual rooms. Does such a thing exist?
Thu, Apr 16, 2009 at 2:02:22 PM | Area and Room Tags
elduderino1234
Maybe I could create an element tag that would actually tag the individual groups for the units. The tag would contain the unit type and number data. However, is it possible to also add area to this tag? Advice is appreciated. Thanks
Thu, Apr 16, 2009 at 2:14:00 PM | Area and Room Tags
As I said ... use the area for the units.  The area limits would be the overall "room" that you want.  Add a parameter for Unit number ... and obviously, the area tag could have the area and the unit number.
Thu, Apr 16, 2009 at 2:23:03 PM | Area and Room Tags
elduderino1234
The only problem is that it isn't possible to create an area boundary on a non-Area Plan view. I want the best of both worlds: area plan on overall plan with rooms. Can i do it?
Thu, Apr 16, 2009 at 2:28:56 PM | Area and Room Tags
I don't think so ... but why don't you use a small unit "key" plan and place that view on the same sheet?
Thu, Apr 16, 2009 at 2:36:31 PM | Area and Room Tags
elduderino1234
Sorry about the double post...
 Can you elaborate on this key plan idea? Is it something that include on the overall floor plan showing the area and unit number of something to be included on the enlarged unit plan sheets?  Thanks for all your help thus far. We're almost there, I can feel it!
Thu, Apr 16, 2009 at 2:46:22 PM | Area and Room Tags
I'm just suggesting that you do an area plan using area tags that are named with the unit number.  The area tag can show the area SF.  You could do this plan at a smaller scale .... maybe with the walls halftone ... and place this plan on your plan sheets.... you could use similar ones on your large scale unit plans as well - but I think I would rater use a legend for those.
Thu, Apr 16, 2009 at 2:48:06 PM | Area and Room Tags
elduderino1234
Here's an idea that I think might work....
 I place two rooms in the same room. They will be overlapping, of course, but it won't matter. I just need, for the schedules sake, the unit type, floor, unit number and then use the areas from the area plan and put it all on one sheet. Sounds good to me. Problem solved
changing the scale of my room and area tags with the scale of my area plan.
Fri, Oct 22, 2010 at 10:38:38 AM
Room tags with area - area not showing up!
Thu, Aug 16, 2007 at 6:54:26 PM
Area Plans & Room Tags
Fri, May 12, 2006 at 3:50:55 AM
Phasing is interfering with Room Area/Tags (I think)
Wed, Sep 28, 2016 at 1:15:48 PM
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
Page generation time: 0.2780
