10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Placing Door in Design Option Error
42 Posts No Rating |
I'm in Revit Bldg 09. Working in a design option, I try to insert a door into an existing wall and get this error: "An insert in a design option cannot be hosted by an element in the Main Model." I am BLOWN AWAY by this limitation! Almost speechless. What an oversight! I thought I could "work-around" this by putting a new wall in place of the existing, but the new wall overlaps the existing and puts up the same error. Anyone else have this issue, or better yet, a work-around that works?
You need a wall in each option - one will host the door. Don't have the wall in the base.
Edited on: Thu, Apr 16, 2009 at 12:55:37 PM
It's not a limitation - if you put a door in a wall you're changing it. Simply click on the wall and 'Add to design option set (under tools).
1 Posts No Rating |
I agree with the first 2. I am redesign a house and want to show a few options one of which would be the door location. The door will go into an existing wall and I should not have to copy the wall to every design option. Same thing goes with lighting I had to delete my ceiling from the main plan in put ceiling in each design option. Furthermore I should be able to demo a wall in a design option and do whatever I want. I would understand if this only happened with NEW construction. But I want to put a doors, lights, and windows into EXISTING walls and ceilings
I know adding a main model object to a design option is not hard but it should be unnecessary and design options should only contain NEW construction. I should be able to create the existing bldg as the main model then using design options do all the demo and new construction I want.
Edited on: Sun, Jun 23, 2013 at 7:06:08 AM
Design Option Error |
Wed, Mar 19, 2014 at 12:28:03 PM
Accepting Primary Design Option Causes Fatal Error |
Tue, Dec 29, 2015 at 3:58:30 PM
Design Option Issue - walls in 1 design option cutting thru a 2nd option |
Thu, Oct 21, 2010 at 11:55:04 AM
Inserting Doors in Options |
Wed, Sep 16, 2009 at 8:11:20 AM
Design Option view setting |
Fri, May 16, 2014 at 8:02:11 PM
