Forums >> Revit Building >> Technical Support >> Topology Following Family
Thu, Jul 7, 2005 at 7:16:20 PM | Topology Following Family
JoeDrevitO
There is a Van including in revit in the "entourage" folder which is a very simple family (a couple extrusions and split faces) and is somehow able to angle itself to rest properly on a topo surface when placed. It has something to do with the reference plane in the family named "3". I deleted everything else in the Van family and put a single rectangular extrusion with work plane on "3" and if placed on a topo surface it will angle perfectly. If I start a new family and try to copy the reference plane and everything exactly and load that into the project it wont follow the topo. The van family is Entourage, I have tried making one from the Entourage, site, and generic model templates. I'm guessing there is some "perpenticular to host" setting somewhere but I cant find it. Please dont suggest just editing the Van family for everything because I would like to actually understand how this works so I can advance. Thanks
Fri, Jul 8, 2005 at 2:48:55 AM | RE: Topology Following Family
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
SETTINGS-->FAMILY CATEGORY AND PARAMETERS-->UNTICK ALWAYS VERTICAL... THIS WILL ALLOW A SITE BASED ELEMENT TO AUTOMATICALLY ADJUST FOR A SLOPING TOPOGRAPHY (WITHIN REASON). HTH.
Fri, Jul 8, 2005 at 12:13:33 PM | RE: Topology Following Family
JoeDrevitO
Beeeeeeautiful! Works perfect Mr. Spot, thanks so much
Revit topology display in cut and elevation views
Thu, Dec 12, 2019 at 4:42:25 AM
Site Plans and Topography.............
Sat, Apr 15, 2006 at 9:52:30 PM
Basic topology and earthworks.
Sat, Aug 3, 2013 at 11:32:13 AM
bathroom interior elevation
Wed, Apr 20, 2005 at 10:12:00 AM
Revit 2013 - Sloping site & retaining walls
Fri, Apr 19, 2013 at 2:55:40 PM
Page generation time: 0.6895
