Forums >> Revit Building >> Technical Support >> Live Linked Revit Details -Like an X-Ref - is there a way?
Tue, Apr 14, 2009 at 5:24:10 PM | Live Linked Revit Details -Like an X-Ref - is there a way?
lynner
I'm looking for a way to link details from another file in a way that they live in the original file and can be updated there instead of the project they're being linked into.  Similar to an x-ref in autocad.  Is there a way?  I've tried File>Insert from File>Views, but that seems to just copy the drafted elements into your project.
Background:
We're working with a large team on a quick schedule and every time we approach a deadline we get 'save to central' back-ups because some of the team members have slower computers.
We'd like to have the detailing work completely live in a different file, which would both keep our project size from getting too big, and keep people out of the central file.
Our project has two buildings which will have many similar details so we would like to be able to link from both projects to the same detail.
Wed, Apr 15, 2009 at 9:48:24 AM | Live Linked Revit Details -Like an X-Ref - is there a way?
TABEST
4 Stars: 4 Votes
If you are using CAD also, you can achieve this, but using Revit, not really.  The problem stems from you using drafting views, when you link in a Revit file, you can't "see" the drafting views, only views made from the model.  If you want it to be live in Revit, you need to create a view (section, elevation, etc.) and then detail it there, on your sheets project, go to visibility graphics of the linked file, override graphics of that view and then choose which view to show in the linked view spot.
Back to the CAD method, if you create your detail in CAD, and then you LINK (be sure to click the LINK checkbox when you import your CAD file) the CAD file into the project on a drafting view.  Now if you change the CAD file, just reload it in the manage links dialog.  Every time you load the project for the first time, you will also get the most up to date...  Just remember, as I get this a lot in my company, reloading latest doesn't reload the links, you have to manually in the manage links dialogue tell Revit to reload your linked file.
Wed, Apr 15, 2009 at 10:51:26 AM | Live Linked Revit Details -Like an X-Ref - is there a way?
lynner
So does anyone know of a way to have a live link to a model view that lives on a sheet within a linked file?
Live Vs Dead detailing
Tue, Mar 29, 2016 at 7:57:55 AM
LInked AutoCAD details into Revit 2009 workset project
Tue, Jun 28, 2011 at 5:07:32 PM
Live Footing Schedule - Linked Model
Fri, Oct 9, 2015 at 10:15:06 AM
Autocad details linked into Revit
Mon, Jun 6, 2016 at 1:54:23 PM
Linked Revit Model Drafting View
Thu, Dec 18, 2014 at 12:39:33 PM
Page generation time: 2.9253
