Forums >> Revit Building >> Technical Support >> yet another pitched roof problem
Tue, Apr 14, 2009 at 12:30:22 PM | yet another pitched roof problem
trad3mark
hey all
ok, so firstly, here's the image of my problem:
http://i40.tinypic.com/2zemjjd.jpg
ok, so what i'm trying to do is move the "centreline" of the roof (the blue arrow) to line up with the internal partition (the green arrow). As you can see, the pitch on the left is at 45degrees and the other is 30degrees. I'm kinda new to revit, we only started it in college this semester, and i've a project due in about a week. Fortunately, if i can get this house done, it's a copy and paste job Winking
any help is greatly appreciated
tm
Tue, Apr 14, 2009 at 1:04:30 PM | yet another pitched roof problem
4 Stars: 205 Votes
So, create a Ref. plane in the center of the wall, then in that elevation view pick in the roof and pick in "Move", select the basepoint in the end of the roof to the ref. plane....
Tue, Apr 14, 2009 at 1:32:12 PM | yet another pitched roof problem
trad3mark
i tried that, but when i moved it, the over hang was WAY too big on one side, and almost nothing on the other, so when i went modify > overhang (or move the lines) it went back to the way it was.
 i also tried attaching the walls, to create a constraint, but i had the same result.
Tue, Apr 14, 2009 at 1:36:41 PM | yet another pitched roof problem
4 Stars: 205 Votes
I think the problem is that, you have the walls constrain to the roof, detach the roof for every thing, then try to move it, after this you can attach again the walls to the roof....
By the way, that roof is "By footprint or by Extrusion"????
Tue, Apr 14, 2009 at 3:23:09 PM | yet another pitched roof problem
tim123
4 Stars: 19 Votes
If you edit the roof are the slope defining lines at the correct angle?
Tue, Apr 14, 2009 at 5:54:20 PM | yet another pitched roof problem
trad3mark
ok, i'll try to put in as much info as possible.
it's done by footprint > pick walls (so i can do the overhang)
when i go into edit, both angles are correct.
I also tried doing it by footprint > lines and i got the same problem, even when the walls weren't attached.
Wed, Apr 15, 2009 at 5:59:14 AM | yet another pitched roof problem
4 Stars: 205 Votes
Hi, see the video: http://www.megaupload.com/?d=JRV22L8T
Pitched Roof Problem
Fri, Jun 10, 2011 at 4:10:32 PM
a pitched hip roof with an arched dormer window and standing metal seam finish
Wed, Nov 13, 2019 at 5:31:44 AM
demolish part of pitched roof
Fri, Jan 13, 2006 at 2:28:37 AM
Place a Vertical chimney on pitched roof with opening
Tue, Jan 6, 2015 at 10:54:30 PM
Pitched, angled & tilted roof
Fri, Sep 26, 2014 at 2:26:26 AM
Page generation time: 1.9462
