Forums >> Revit Structure >> Technical Support >> Path Reinforcement
Tue, Apr 14, 2009 at 11:30:40 AM | Path Reinforcement
VANREVIT
VANREVIT Avatar
5 Stars: 2 Votes
Good morning to all,
I am trying to find out, if there is a way to edit the way PAth reinforcement tags show up. For instance, I want ot place some bottom bars but instead of the bottom bar reading:
15M(9'-10"Winking @ 1'-2" BOT (and showing a solid line)
I would like it to show:
15M09.10 @ 14" (and showing a dashed line
 I tried object styles, but if I change the line type, it changes also the arrow line type, I tried Line work, but it won't let me change anyhting.
One solution would be to draft the rebar, but for that I can't find a double arrow to show extents of the path reinforcemnt. it seems that the only way to show a double arrow is using a path reinforcing tag.
I tried editing the Tag and couldn't get it to work.
Can anyone Help?
Cheers!
Vanrevit
Welcome to the REvitlution!!!
path or area reinforcement in raft foundation
Sun, Aug 29, 2010 at 1:16:18 AM
path reinforcement tag and symbols
Sat, Dec 7, 2013 at 12:16:36 PM
TAGS must be caps lock
Sun, Aug 29, 2010 at 1:27:51 AM
Rebar/Reinforcement Scheduling Area Reinforcement
Wed, Mar 9, 2011 at 4:59:36 PM
Reinforcing Tags
Thu, Jan 2, 2014 at 1:15:45 PM
Page generation time: 1.8749
