Forums >> Revit Building >> Technical Support >> Gable End Returns and Porkchops
Mon, Apr 13, 2009 at 12:04:25 PM | Gable End Returns and Porkchops
mverzier
I cannot seem to find anywhere how to create Gable Roof end returns or porkchops for a residential structure.  Does anyon ehave any ideas, tutorials, notes anything on how to accomplish this?
 Thanks!
Mon, Apr 13, 2009 at 7:59:39 PM | Gable End Returns and Porkchops
jarosa
jarosa Avatar
4 Stars: 5 Votes
I created a family. I made the extrusion that attaches to the fascia with a parametric angle. I don't have Revit here but I'll try to remember to make it available tomorrow. I found i have to get it into the correct location i have to move/copy/mirror it in elevations.
In any case it's a super simple family. In fact, before this family, i started off with an in place family that was just one triangle shaped extrusion.
Tue, Apr 14, 2009 at 5:00:19 AM | Gable End Returns and Porkchops
Space
Making a porkchop is easy.  Sautéing first over high heat and then covered over low heat helps to prevent the chops from turning dry. Brush with a light olive oil and garlic, then serve this with fresh, warm applesauce and herbed rice on the side.
Or you can use the soffit tool or an in-place family, I have used both methods sucessfully.  There is a post here with some examples http://forums.augi.com/showthread.php?t=3734
gable returns
Thu, Jul 15, 2010 at 10:37:11 PM
gable returns
Wed, Jun 22, 2005 at 10:55:56 PM
soffit returns
Tue, Aug 29, 2006 at 4:06:42 PM
Gable End Fascia
Wed, May 23, 2007 at 5:45:50 AM
Gable End Wall
Tue, Mar 20, 2007 at 11:48:35 AM
Page generation time: 0.9100
